Bolts not coming off
Old 06-17-06, 04:45 PM
K
I have a 1999 Honda CRV. I am trying to take the Heat Shield top and bottom covers that go over the Catalytic Converter. Unfortunately 3 out of the 4 bolts are strip or frozen. I tried a 12 Volt drill to drill a hole in the 3 bolts I cant get off. The drill barely makes a hole and cant seem to drill through. Please advise best way or tool to cut or drill or just get these bolts off?
Old 06-17-06, 05:06 PM
DaVeBoy's Avatar
What kind of head is on the bolt on the underside where you can get at it, and how is it secured on the top?; a nut?...or, just the bolt threaded into some other piece of metal?
By stripped, do you mean that it just spins in circles but won't back out? And by frozen, you mean that it won't turn? Can't advise on this till we know the head type of the fastener?
Old 06-17-06, 05:07 PM
P
Never been under a Honda (car, that is). That being said:
Perhaps you can get a hacksaw blade between the two cover halves and saw the bolts in two?
How 'bout grinding away the nut or boltheads (whichever are down and easiest to get to?
In the future, whenever working on exhaust parts, try a bit of liquid wrench first. This sometimes disolves enough rust to you can turn the bolt, or nut. Usually it doesn't though.
Just some thoughts.
Old 06-17-06, 05:29 PM
K
Thanks for quick replies.
Yes this is on underside and the top part has nut on it.
Frozen meaning every time I tried to turn it just stripped the bolt and nut so they became more rounded and I couldnt use any tool to get them off.
What tool can I grind them with?
If I use a Drill would it maybe be better with an 18 volt drill and brand new sharp drill bits?
Please advise.
Old 06-17-06, 06:25 PM
nap's Avatar
nap
nap is offline
New Member
Received 1 Vote on 1 Post
Are you going to replace the heatshield?
If not, a hammer and sharp chisel is the low tech way of cutting the bolt.
Old 06-17-06, 06:27 PM
Former Member's Avatar
I have had good luck with cutoff blades in this situation, a air powered end grinder with a cutoff blade can be very useful in hard to get at spots. Be careful though as those cutoff blades throw a lot of sparks and debris, so be sure to wear your gloves and safety glasses
Old 06-17-06, 06:31 PM
K
I am replacing the Heat shield.
I dont have a air line so I will have to use electrical.
Will an 18 volt drill with new sharp drills be something to consider?
Old 06-17-06, 06:37 PM
nap's Avatar
nap
nap is offline
New Member
I would worry less about the actual drill motor and just get a good quality drill bit. Some of the cheaper bits are not quality and dull too easily. Drill slowly and use a very considerable amount of pressure when drilling.
Old 06-17-06, 06:52 PM
meatloaf2's Avatar
Just use a Dremmel tool with a cut-off wheel.
