98 escort dies when ac is on at stops
Old 06-19-06, 07:13 PM
Question 98 escort dies when ac is on at stops
98 escort (2.0 auto)idles fine with without ac on around spec (650-800)
when ac is turned on and clutch engages, engine stumbles(idle) when driving or if throttle is opened with ac on vehicle dies when throttle is closed. idle is adjusted by the computer. what else could it be. i am a honda tech and with those i would inspect vehicle ide and compressor lock up i have no idea on this ford
Old 06-19-06, 08:18 PM
rpt
rpt is offline
First thing I always check with rough idle are the vacuum hoses.
Old 06-20-06, 08:51 AM
His problem is with in computer not bumping the idle rpm up. I am not sure how that vehicle is setup to do it.
Its not a vacuum problem. That vehicle may not even bump the idle up. It may just disable the alternator until the engine speed picks up. He needs some one with a shop manual for the car or alldata
