96 Ford Van noisy rear
Old 06-21-06, 05:03 PM
Handy-J's Avatar
A buddy of mine has a van that is making a noise in the rear.
I think it's new...he says it's been there for a while...
It happens whenever the van is moving...but takes a few feet of rolling before it starts after changing from forward to reverse or vice-versa.
He thinks it's the brakes...I think it's something in the rear.
The noise is similar to the sound of oversize tires rubbing on the wheel well during a sharp turn. Kindof a buzzing/grinding sound.
And no...it's not a tire-rub anywhere.
Old 06-21-06, 05:43 PM
DaVeBoy's Avatar
Sounds like time to start disecting.
Old 06-21-06, 06:05 PM
nap's Avatar
nap
nap is offline
New Member
Received 1 Vote on 1 Post
Are the tires wearing properly? I have had tires that wore so badly that it sounded as though I had big mudders on the car.
Old 06-21-06, 07:53 PM
Hard to say since he doesn't say what speed the vehicle is going to produce the sound
Old 06-21-06, 07:58 PM
nap's Avatar
nap
nap is offline
New Member
It does seem very simplistic. It is just one of many htings that could be happening and to take a look at. I had the noise more or less idling through a parking lot. It was actually nearly unbelivable the level of noise caused by those tires.
Old 06-22-06, 08:08 AM
Handy-J's Avatar
It's not the tires...they are wearing normally...I think they are about 2 years old.
The noise starts quickly...less than 5mph and doesn't go away.
from what I observed...it starts within 1 full tire rotation when going in forward or reverse.
Hope that helped.
Old 06-22-06, 08:17 AM
Take the tire off and shake it to see if anything is inside it. Check the bushings for rot. Check the wheel bearing.
Old 06-22-06, 08:28 AM
Handy-J's Avatar
The noise can be heard equally on both sides of the vehicle (which is why I was thinking something in the rear...I told him to check for Diff. oil)
I didn't see anything on his driveway or leaking off the axle.
