1996 cutlass supreme
Old 06-22-06, 03:30 PM
looking for reasons that may cause the engine to stop. The engine stops after 3 or 4 seconds. It only happens when it is hot outside. Even when I start it for the first time. Outside temp is above 90 . You can start the engine again and again and the same thing will happen. Any thoughts?????
Old 06-22-06, 03:48 PM
fuel filter, would be my first thing in question , the whole 90 degree thing doesn't matter, tolerances are not that tight on anything to say at 80 it will be fine and 90 it is not so diagnosis will begin by neglecting the temp info. The only thing that responds to temp changes that precise is the air intake temp sensor. And it would not cause a problem like this even if you disconnected it. When you say at such and such temp that shows characteristics of a bad electrical connection.
I say fuel filter first because it seems that the pump is building pressure before the engine is running and then it cannot keep a constant flow so it dies out. Thats where I would begin with this problem. If only I could hear the motor as it dies I would be able to better help. So we have to start here.
See if you can keep the vehicle running right after it turn overs by keeping your foot down on the gas and then try driving it.
Old 06-22-06, 05:16 PM
The fuel filter has been changed. I know it sounds strange but thats what happens. The car sits in the drive way durning the day gets hot and will not stay running. try it later and it works just fine. It does not have any problem with starting. You can press on the gas and the motor rpm goes up then it just stops.
Old 06-22-06, 05:51 PM
now your description fits an idle air control motor on the throttle body.
Old 06-22-06, 06:06 PM
davzack's Avatar
A guess: failing ignition coil or ignition module...expensive guessing on this particular vehicle ($45 a coil and $100 for a module). A tough to diagnose problem...maybe not a DIY instance.
Old 06-22-06, 06:24 PM
It may be expensive unless he goes to a junk yard. We have it narrowed down to non-moving, non-bearing using parts. So junk yard parts are a perfect candidate.
Old 06-23-06, 02:47 AM
I would suspect the factory antitheft system causing the car to start and die recomend you see a shop or dealer for diagnossis, might want to ask any independent shop if they are capable of diagnosing the antitheft system before even taking it to them.
im sure temp does play a big role in alot of electronic failures.
