Honda CRV front end noise
Old 06-23-06, 05:01 PM
daswede's Avatar
I have a 2000 Honda CRv that makes a grinding noise when turning left. Any thoughts on what it might be?
Thanks
Old 06-24-06, 04:47 AM
the_tow_guy's Avatar
Received 48 Votes on 38 Posts
CV joints don't usually grind, they click; but noises while turning often point that direction. Check your front brake pads for wear also.
Old 06-24-06, 05:39 AM
nap's Avatar
nap
nap is offline
New Member
Received 1 Vote on 1 Post
I was thinking possible wheel bearing problem. The thing with wheel bearings gone bad is that they usually make some noise while going straight line as well, just worse when turning (more load on them)
I have seen strange things such as calipers coming loose causing odd noises (sometimes grinding) or had brakes in general do odd things.
Pull the wheel where the sound seems to me eminating from and look fro wear marks. Check the brake pads as well while there.
Old 06-24-06, 06:33 AM
daswede's Avatar
thanks everyone. It's raining here ,so i'm off to the garage. Your suggestions are appreciated.
Old 06-24-06, 08:37 AM
Post back what you find & fix, swede.
Old 06-24-06, 11:09 AM
daswede's Avatar
Sure will!
Old 06-26-06, 10:56 AM
daswede's Avatar
update:
Front brakes and rotors were the culprit. tech. checked wheel bearings and back brakes,and they were good.
Thanks again
