1988 Ford F150, will not engage reverse
Old 06-27-06, 06:03 PM
mikesmalleng's Avatar
I have an "88" Ford F150, 4.9L Eng. 4sp W/OD Transmission, Hyd, clutch. Just today i got in and when I went to put it in reverse it would just grind and if it do go in it just jumped back out. It has grinded a few times before but for a only a second and then engaged. I`ve had the truck around 4 years and have change the (Auto) transmission fluid twice, once just recently.
NOTE: Since I`ve had it I`ve never been able to get it into O/D.(not that I ever needed it)
If that tells you anything .
Any ideas of this problem will be much appreciated.
Mike
Old 06-27-06, 06:46 PM
billys68ss's Avatar
Ummm.... Your post is kind of contradictory.... You say you have a hydraulic clutch, but then you say you have changed the automatic trans fluid.....
Which is it? Is it Manual or automatic?
Thanks,
Billy
Old 06-27-06, 07:31 PM
The post is pretty clear, some manual transmissions use automatic fluid in them. I would need to see diagram of his transmission to better help him.
Old 06-27-06, 07:36 PM
nap's Avatar
nap
nap is offline
New Member
I own a '98 F150, manual trans. It uses auto trans fluid in the tranny and it does have a hydraulic clutch.
Old 06-28-06, 06:32 AM
davzack's Avatar
If the other gears are working correctly I would suspect internal transmission problems as opposed to a problem with your clutch. Still you might make sure your clutch resivoir is full and there are no leaks from the clutch master/slave cylinder. Sounds though as if you might be having to get the transmission overhauled...sorry.
Old 06-28-06, 10:27 PM
This is a Standard 5sp overdrive with a Hydraulic clutch, Automatic transmission fluid is use in this instead grease.
Mazda 5OD, Yes Mazda trans, on a Ford.
Old 06-28-06, 11:03 PM
There`s a break down of it in the Clinton 87-88 Bronco and F150
It shifts very smooth into all forward gears.
My wife is Bi-polar and in an episode. I just found out that she took the truck out late that night and was ramming the gears because she was pissed off at the world.
I also noticed that this trans, has separate forks for each speed.
Her outrage may have damaged the reverse fork in some way. I`ll have to take it in (as much as I hate to) and have it checked out.
My wife can get very violent and destructive when she`s in these episodes.
Thanks a lot for your help
Old 06-29-06, 06:04 PM
billys68ss's Avatar
Im well aware that some manual transmissions use ATF instead of gear oil. I was intending to clarify.
It sounds like there is internal damage. If you drain the fluid into a clean container maybe you can see if there are shiny pieces or other tell tale signs of failure.
Good Luck with it,
Billy
Old 06-29-06, 06:28 PM
nap's Avatar
nap
nap is offline
New Member
Thanks,
Billy
In this post it sounded as if you were questioning the fact that the of a manual trans using ATF. I think (I know for me) the others were just letting those who are unaware that some manual trans use ATF.
That;s all.
