1997 transport
Old 06-28-06, 03:03 PM
B
1997 transport
backup lights will not work. I have changed the bulbs and fuse and still don't work. What else can I check?
Old 06-28-06, 05:51 PM
H
the reverse light switch
Old 06-28-06, 06:40 PM
davzack's Avatar
Can you make them come on by moving the gear selector up slightly while it's in reverse? I've seen a bunch of cars where the cable to the range selector switch on the transmission is out of adjustment...causing the reverse lights not to come on.
If they still don't come on when you wiggle the gear selector you may have a bad transmission range selector switch (a.k.a. transmission position switch a.k.a. transmission park/neutral position switch).
