1994 Grand Marquis power window regulator...
Old 06-29-06, 02:38 PM
I've seen bits and pieces of how to replace the driver's and front passenger's window regulators.
Does anyone have a step by step procedure with diagrams to help me out? Or where to go for this information??
I've taken the door panels off and do NOT want to break anything (or allow Murphy to rear it's ugly head). I also understand I will need to drill rivet type fasteners and replace with nut & bolt?
Thank you for your time,
Jeff-san
Old 06-29-06, 04:25 PM
davzack's Avatar
Check your PM
Old 06-30-06, 11:06 AM
If you use screws besure to smash the ends so there is no chance of the bolt coming off on accident over time.
also a hand pop rivit gun you can pick up for under $30
Old 06-30-06, 12:26 PM
Well, as for the rivit gun, you can get the regular ones on sale for as cheap as ten bucks, however with my car, the rivits were 1/4 inch rivits, that required a heavy duty rivit gun that somewhat resembled a bolt cutter more than a rivit gun.
Old 06-30-06, 01:09 PM
Rivets
When I replaced the mechanism in a 91 G Marquis I used screws in place of the rivets. However, I used nylon-filled locknuts. The procedure is fairly obvious and should'nt be all that troublesome.
