1998 chevy blazer brakes
Old 07-01-06, 01:48 PM
I think it's the brakes because they squeak when i use them...but the blazer is squeaking the same sound just when i drive as well...i know the brakes are a hurtin...but does it do this too sometimes????
Old 07-01-06, 06:32 PM
billys68ss's Avatar
I dont know what language that is, but i think I have deciphered that your brakes are squeaking all of the time? Is this correct? If so just take a wheel off and take a look. If you see grooves in your rotors then you have a brake problem. If not, look at the pads. There should be a little metal bit sticking out from the pad that is posibly coming into contact with the rotor making this noise. This is called an indicator, or squealer in laymans terms. It is designed to let you know that you need brake service before any damage is done.
Hope this helps ya,
Billy
