Mazda B2200 turn signal
Old 07-05-06, 12:09 PM
1990 Mazda B2200. Right front turn signal quit working, right rear flashing fast. New bulb, clean socket with no corrosion, wire harness clean. Any ideas?
Old 07-05-06, 12:34 PM
find the wire at the base of the steering column going to the right front turn signal and use a test light to see if its getting power through the turn signal switch if no power would suspect bad switch, if it has power has to be wiring or bad connection problem or bulb.
Old 07-05-06, 08:52 PM
davzack's Avatar
I still think you may have a problem somewhere at the bulb/socket I would think that if the switch was bad the rear turn signal wouldn't come on. Use that test light and probe the battery + wire back from the socket and see if you get anything. If you do then you are talking about an internal problem on that socket (not a good contact with the bulb) or even another bad bulb.
