98 Intrepid Electrical
Old 07-07-06, 07:12 AM
skl
skl is offline
Just had a friend replace the glass for my driver side power window. Well the window works fine, but now I don't have a radio or heat/ac, the overhead console resets itself each time power is on/off, the remote mirrors, door locks and interior lighting are also gone. All this and the check engine light is on. I've taken the panel off to see if a wire was visibly broken or cut and nothing. Any ideas or direction would be great.
Old 07-07-06, 07:31 AM
I need all the schematics of the vehicle essentially a book.
But you may want to start testing relays. Also the only thing I could see that your buddy could have done was short a wire in the door which would have blew the fuse for that circuit. This is something else maybe a relay, or possible a loose contact to a fuse in the box, or a loose wire / internally broken wire. check battery connection. This one is more than likely going to be deemed not for an electrical novice, and would be near impossible with out all the schematics and coming up with a plan to start testing.
Check the big high current fuses to
Old 07-07-06, 07:41 AM
skl
skl is offline
Is there a chance that a fusible link is anywhere in this harness? I checked all the fuses in the cab and even pulled the fuses from the engine compartment, and no results.
Old 07-07-06, 07:43 AM
Normally fusible links aren't in harness.
Old 07-07-06, 11:45 AM
it may have a fusible link but will generally be close to the battery and positive cable not in the harness but usually runs right with the harness with the fusible link on the outside of the harness, suspect it has to be a fusible link problem or fuse problem in the underhood fuse box that would cause all of those things not to function.
