92 Chevy Astro Power Window Trbl
Old 07-08-06, 08:29 AM
When I Hit The Up Or Down Sw The Window Moves A Couple Of Inches In The Indicated Direction Very Sloooooooooowly And The Stops..i Have To Wait A Few Minutes And Repeat The Process To Raise Or Lower The Window....obviously The Problem Will Only Get Worse...any Ideas?
Old 07-08-06, 11:45 AM
sounds like it needs a new window motor, as it is blowing the circuit breaker after a couple of seconds and you have to wait for it to reset itself before it will move another couple of inches and blow the circuit breaker again.
Old 07-09-06, 12:21 PM
billys68ss's Avatar
It could be a window motor that is worn, or it could be that the window track is out of adjustment. When the window is about halfway up give the window a little tug, side to side and compare it to the other side. If the play is excessive then it could be that the window track is ill adjusted and the window is binding in its travels. If you have alot of up and down play, then you are looking at a window regulator problem.
Good Luck.
Hope this is helpful to ya,
Billy
