1992 Olds Driver Information Center
Old 07-10-06, 09:55 AM
I have a 92 Old 88 Royale LS. Several weeks ago the Customer Information Display started to go haywire. The LED display turned into multiple flashing squares and the system emits a warning sound. If I disconnect the battery the system returns to a start mode asking for date and time. The controls on the info center will not let me enter information and after a short time will returns to the flashing/warning mode. I've taker the dash apart to see if I can find the source of the noise and at least disconnect the buzzer. Everything is made of circuit boards so no buzzer. What's my next option?
Old 07-10-06, 10:52 AM
with out schematics to very a constant supply of power to each power line and then measuring the resistance of each ground. There isn't much you can do.
Old 07-10-06, 08:35 PM
davzack's Avatar
That's the problem with those types of displays...about the only thing you can do at this point is call a salvage yard and get a used one to replace it with. Getting one from a dealer would be waaay to costly.
Old 07-11-06, 09:19 AM
Thanks, it's off to the salvage yard.
