95 Saturn Help
Old 07-10-06, 10:45 AM
Question 95 Saturn Help
I have a 95 Saturn SL/1. Replaced plugs and air flter. Car surges when accelerating or under load (i.e. AC on). Possibliities - Oxygen sensors or throttle sensor. thoughts?
Old 07-10-06, 10:54 AM
possible mas, fuel pressure regulator to don't forget
Old 07-10-06, 08:34 PM
davzack's Avatar
Is the check engine light on?
Old 07-12-06, 06:09 AM
95 Saturn Help
the check Engine light does not come on. Ithe care runs fine when first started. after warming up, it starts to surge. when accelerationg, the car does not seem to get any power. , it just revs up. whe the AC is on, the car will idle rough.
Old 07-12-06, 08:07 AM
start with the simple stuff
Did you have this problem before you changed the plugs and filter?
if yes-What did the plugs look like? Did the all look about the same? Write back
If no-make sure intake air duct is on tight and has no cracks or holes and all smaller hoses are ok too-make sure plug wires are good, on tight and on the right plugs
it sounds like your fast idle on start-up is masking your problem
Old 07-12-06, 08:42 AM
The problem existed before chaging pluga and filter. That's why I made the changes. The old plugs were worn, did not look too bad except for the wear. Gapping was probly off due to the wear and tear.
Old 07-17-06, 06:51 AM
Problem fixed. It was the spark plug wires.
