Light bulb
Old 07-11-06, 12:19 AM
Light bulb
How do I change the driver side, front light bulb that turns on with the headlights, but it is behind the orange cover next to the turn signal orange cover? The car is a 1996 Geo Prism. Thanks.
Old 07-11-06, 06:02 AM
davzack's Avatar
The bulb is removable from the headlamp unit separately. Access is gained from the rear of the unit through the engine bay. Open the hood and look directly behind the headlamp and you should see a ring holding the lamp. Disconnect the harness connector, unscrew the ring, and pull the lamp out.
Old 07-11-06, 06:22 AM
Which screws on the inside of the hood need to be unscrewed in order to reach the light socket?
Old 07-11-06, 06:52 AM
There will be pictures in the owners manual, this is a job for haynes or chilton books at auto stores
Old 07-11-06, 08:43 PM
Thanks. I finally figured it out after discerning what the owner's manual said.
I should have thought of that first.
