1992 Chevy Caprice
Old 07-11-06, 05:59 AM
Question 1992 Chevy Caprice
how do you replace the fuel pump for the 1992 caprice with a 305 engine
Old 07-11-06, 06:01 AM
drop the gas tank. spin the top/ or unbolt where the pump is. pull it out. Reverse procedures
Old 07-11-06, 06:28 PM
davzack's Avatar
First, make sure you relieve fuel system pressure. Disconnect the negative battery cable. Take off the gas cap. Relieve fuel pressure at the pressure connection by depressing the valve with a small screwdriver while holding a shop rag around the connection.
Next, remove the fuel tank. Drop it slightly down and make sure you disconnect all the fuel lines, vapor hoses, filler hose, and electrical connections from the top of the tank before you drop it all the way down.
Remove the fuel pump assembly from the tank.
Replace the pump in the assembly. Make sure your pump includes a new strainer.
Put it all back together. This is a great time to also replace the fuel filter.
