air conditioner problem
Old 07-13-06, 09:11 AM
i own 2000 chevy silverado 100,000 miles i noticed my air
conditioner stops cooling if i run continious for a couple of hours whats causing this problem.i had the system charged with freon.
still same problem.
Old 07-13-06, 10:01 AM
Define stops cooling. Is the air coming out the same temperature as the outside? Hotter? just a bit cooler?
Is the compressor clutch still engaged? if you dont know, please check, this is important.
After it stops cooling, does it work again the next day when you start driving?
Old 07-14-06, 07:17 AM
the next day the unit works fine .seams like unit freezes
but when it sets up overnight it start working fine.compressor is working fine. i think there may be a leak somwere in the system
Old 07-14-06, 07:26 AM
thiggy's Avatar
That is a typical symptom of low freon. You probably do have a leak. Get it repaired; don't use one of those 'miracle' stop-leak products. They will create more problems than you already have.
Old 07-14-06, 10:11 PM
Yeah, I would also suspect low freon. As the system runs and pulls freon out of the low side, the pressure eventually drops too low and the cutout switch stops it. Then after you park and it has time to even out, there is enough low side pressure to keep the low-side switch from cutting out. I would recommend that you check both the high and low side pressures with a manifold guage set.
Old 07-15-06, 04:36 PM
i found the problem the pressure cycling switch was bad
they are known for going bad on GM vechicles.oreilly had one
for twenty eight dollars.problem solved.
Old 07-17-06, 04:00 AM
thiggy's Avatar
Dnauls - Thanks for posting back with the outcome of your situation, which sheds more light for us reading. Glad to hear your repair was minor.
Trackbacks are On
Pingbacks are On
Refbacks are On
