1989 Corvette Coup overheats in slow traffic
Old 07-14-06, 10:38 AM
Unhappy 1989 Corvette Coup overheats in slow traffic
I have new radiator, thermostat (2), 10 bladed front fan, rear fan is working, new upper and lower hoses from radiator, yet if ambient air is above 80 I can not run air conditioner with out reaching 240+ in slow traffic. Block check was negative no mix of coolant & oil. Compression is 145 to 160 all around. I know vettes run hot, but not this hot. Can anyone please offer a sloution? Thanks.
Old 07-14-06, 11:53 AM
I think the a/c condensor is in front of the radiator on a C4, are you sure the condensor is clear....they can pick up a lot of road debris and clog up pretty thoroughly which can lead to overheating.
Old 07-14-06, 01:42 PM
Tune port right.
Exactly what he said that car grabs its cooling air from only few small spots. Is that one an electric fan, electric and mechanical. they went through so many changes on the c4 I don't even pay attention to what varied from year to year. And does it come on right away when you turn the A/C on and then off when you turn it off.
Also vettes don't run hot, but the passenger compartments always get very hot.
You replace the radiator cap to along with the radiator, that little cap can make a difference believe it or not.
Old 07-14-06, 04:35 PM
Try a new temp guage if only a temporary one, I had a 86 Astro that would go very hot during any type of warm humid weather after checking it out I found it was a problem in the electrical system/factory guage so rather than rip out the dash I learned to live with it. Have a nice day. Geo
Old 07-14-06, 06:59 PM
A weak or failing water pump would make the engine run hot at idle, but not at speed
Old 07-14-06, 08:01 PM
is the engine original or has it been rebuilt or replaced with a rebuilt?
does the fan cycle on and off when idling and the a/c off?
Trackbacks are On
Pingbacks are On
Refbacks are On
