help! 1990 toyota camry shuts off when hot!
I have a 1990 toyota camry 4cly with 90,000 miles, after running for like 20 minutes it just shuts down. It then cranks but won't start After it cools down maybe 20 minutes it starts right up again. After like another 20-30 minutes all the lights come on and it shuts down again. Can someone please help me with this problem Thanks in advance
Shutting off Camry
OMG-you have described the exact problem I am having with my 94 Camry.
Which relay did you replace?
So far we have replaced the:
Spark plugs
PVC valve
Cleaned air intake flywheel
Air filter
Fuel pump
Coolant temperature sensor/ECT
I'm on my last legs......Help
cpj121
Spark plugs
PVC valve
Air filter
Fuel pump
cpj121
