1988 Chevy Celebrity Brake problem
Old 07-16-06, 07:35 PM
N
I am having a problem with my 88 Celebrity. The brake peddle goes all the way to the floor and the brakes just barely grab. I have check for leaks and there is none the brake fluid is full. I replaced the back brake shoes and checked the brake cylinders they seem to be fine. When you push on the brakes the peddle goes to the floor with a wooshing nosie like excaping air. What could be the problem?
Old 07-16-06, 08:13 PM
davzack's Avatar
Sounds like you have a problem with your master cylinder bypassing internally. It will need to be replaced.
