Air condensor
Old 07-20-06, 06:19 PM
Exclamation Air condensor
I have water under the passenger seat in my Chrysler Sebring. I think it is the A/C condensor output hose that is blocked. Anyone have this same problem and is it easy to fix yourself? Anyone know how to do this? Thanks.
Old 07-20-06, 06:40 PM
davzack's Avatar
You are correct that it is more than likely a clogged evaporator drain tube. If you look up under the car with the AC running, you should still be able to see a few drops of water coming down unless it is completely clogged. The drain tube usually comes out under the passenger side near the firewall. Get a coat hanger, crawl up under there and run the coat hanger up the tube. That should clear the blockage.
Old 07-21-06, 03:26 AM
New guy's Avatar
I'd like to ad, get your head out of the way when you poke the coat hanger into the drain or you'll get wet. .
Old 07-21-06, 06:58 AM
the_tow_guy's Avatar
A shop vac works well, also, and will suck out the crud to help prevent a reoccurrence.
Trackbacks are On
Pingbacks are On
Refbacks are On
