92 toy pu 22re timing chain replacement
Old 07-20-06, 09:45 PM
L
Question 92 toy pu 22re timing chain replacement
I need to change the timing chain on my pu. Do I have to remove the head?? I just did that to groove it and that is an all day job.
thanks I've got trhe parts but my old book says remove the head just does not seem right there has to be a trick hopefully
Old 07-21-06, 08:10 AM
L
Thumbs up leave it
I found a site that walked me throughthe whole process something like 4x4wire anyway thanks now wait for the new moon and do the job!!!
Old 09-05-06, 09:21 PM
P
22R head gkt
drain coolant, remove air horn , remove fan & shroud. remove RAD. you don't have to but it makes it easyer. un bolt p/s pump ,unbolt a/c comp . un bolt heater by-pass tubes on both sides of the t-cover. dont forget to remove th 12mm bolt going through the head to the t -cover. when you put the t-cover back put rtv at the coner of the head & block. also put a small bead across the top of the t- cover & across the oil pan .make sure the the TIMING COVER DOES NOT HAVE A HOLE IN IT ; FROM THE T -CHAIN RUBBING IT.
