700R4 rough shift
okay its in an 85 gmc safari came out of a z28 camaro shifts real hard into secon chips the tires every time. also must be at high speed for it to grab 4th 3rd will some times shift smooth other times i need to let off the gas for it to grab not nailing it either this is all under normal operating speeds and acceleration
need to mention engine has only 4k miles and tranni only has maybe 500 miles
Need to check the throttle valve transmission cable for proper adjustment. Check where it connects at the transmission as well to make sure it hasn't been bent or broken. If it's just one click off of adjustment at the throttle body, you'll get all sorts of weird shifting.
I think he means the detent line.
I would also get a transmission Flush at a lube shop. Not a fitler change.
How much of the history of this tranny do you know of. It could have a shift kit in it.
