Plugs and Wires
Plugs and Wires
Hello! I am trying tto change the plugs and wires on a 98 Plymouth GrandVoyager 6cyl .
The front three are simple enought but how can I do the back three? could someone please help with this?
Thank you !!!
rcjazz
Thank you !!!
rcjazz
Keep checking back for someone with more specific information for your particular engine, but the back three plugs on transverse mount V shape engines have become hidden on many vehicles, as you noticed. On some engines, there are other parts you need to remove to get to them, others still require you to actually disconnect an engine mount and roll the engine forward. It's gotten to the point that changing spark plugs is not always a DIY task anymore.
Up from underneath you can sneak behind the motor and get them. thats how I do the back ones on the minivans. get a 3/8" swivel it will help a lot to. but yep from behind the motor and underneath. go uop between the firewall and motor. Or you can use a lot of swivels and get on top of the motor and try.
