91 Toyota Camry minor problems.
Old 07-29-06, 11:43 AM
My Camry Station Wagon has a couple of problems I would appreciate some help with. The first is the light out indicator comes on when I use the brakes. The brake lights are good and they are the correct ones 1157s I think. The other problem is the heater blower does not come on in the low position. The other speeds work. I think I can replace the parts if I know what and where they are. Any help will be appreciated.
Art
Old 07-30-06, 01:33 PM
davzack's Avatar
You probably have a bad Light Failure Sensor...located inside the trunk on the left side up against the fender...should be yellow I believe. The other part which is probably bad is the blower motor resistor.
