Loud Whistle
Loud Whistle
'96 Cavalier, 2.2 auto and air, 107k. When accelerating I can hear what sounds like a whistle. I've checked all air intake connections and all vacuum lines are in order. Running great and doesn't seem to make a difference whether ac is on and no difference between nuetral and in gear. I used a stethoscope and ruled out the alternator, ac compressor, ps pump etc....can't seem to find where the noise is coming from....any ideas? Thanks!
DO NOT PUT YOUR FINGERS ON OR NEAR THE BELT WHILE IT'S MOVING! ! !! ! ! ! ! ! ! !! ! ! !
They sell a compound in an aerosol can to stop belt slipping and squealing. Might have to spend a few bucks but it's a better idea. Phil
is it possible you have an exhaust leak. When accelerating, the pressure rises in the exhaust system so any leaks would tend to show up. I have heard some present as "whistles"
If you take a large heavy rag and preferably some leather welding gloves if available you can plug the tailpipe while the car is idling. Any such leaks will generally be heard from that.
Be cautious. The exhaust does get hot, even to the tailpipe. If you do this when the engine is cool, the exhaust pipes will not have had a chance to heat up YET. But it will very SOON.
The actual exhaust will also get hot very quickly.
Thanks NAP....that may be it. It is definitely not a belt or pulley and I've ruled out the pump and compressor via a stethoscope. I noticed the manifold to exhaust pipe joint appears to have had some movement although it's tight....looks shiny. I'll check it out this evening.
ok, ruled out an exhaust leak. The noise seems to be more of a whine that increases with engine speed. It started all of a sudden....makes no difference with ac on or off, turning the s/wheel etc. It is definitely not a belt/pulley/compressor/alt/or power steering pump. Sounds as if it's coming from the engine itself. Engine is running strong and normal....temp is fine and fluids are staying normal. Trans fluid is ok and looks new.
May I asked how you ruled out all of that stuff? The correct way would be to remove all your belts and then start the engine...if the sound's not there anymore it's in one of the belts/pulley/compenents.
