A/C condenate drain on Taurus
Old 08-01-06, 08:24 AM
no_sparks
I've got a/c condensate draining onto the passenger floor of my 2003 Taurus. Does anyone know where the drain line is on this car?
thanks,
Brian
Old 08-01-06, 11:33 AM
Jack the vehicle up, go under neath look up around the passenger side area by the firewall for a short tube then poke a wire up it. keep your face away from where it is when poking around.
Old 08-01-06, 11:46 AM
no_sparks
okay....thanks...
Old 08-01-06, 12:00 PM
Actually you shouldn't have to jack up the car. Just open hood and stand behind pass. front tire and look straight down pass. side firewall---you should see a small hose coming out and turning downward. Problem is the hose may be loose coming out of the evaporator drain reservoir inside car. Check it by feeling under the pass. foot area adjacent to firewall. You'll find the water leak there, and may need to remove hose end and install a small hose clamp to stop leak...good luck because it's a damn tight space.
