Maxima Side mirror
Old 08-01-06, 01:54 PM
P
Maxima Side mirror
I have 1997 Maxima GLE.
The right hand side mirror is broken.
I called the dealer and they are quoting Parts ($205) and Labor ($120).
I checked the same part on Ebay for $52 ($36 part and $16 shipping)
My question is can I get this part from ebay and Fix it myself?
How easy to fix?
Appreciate you help on this.
thanks
Old 08-01-06, 02:14 PM
The hardest part is taking the inside of the door off and mirror should just be a few bolts.
Old 08-01-06, 04:03 PM
the_tow_guy's Avatar
Pretty easy job; and the sounds like about the right price for an aftermarket.
Old 08-02-06, 01:05 PM
P
thanks for the reply.
what do you mean "taking the inside of the door off"?
I could not see the any nut or bolt.
How do I open it?
Please help me.
thanks
Old 08-02-06, 01:21 PM
Where the mirror is mounted on the outside of the door, look directly opposite on the inside. there should be a trim piece of some type that will either snap off or may have a fastener of some sort holding it on. Once that's removed the mirror attaching screws/bolts will be visible.
Old 08-06-06, 03:08 PM
P
Thanks for the reply.
I tried to take of the casing. 2 plastic pins snapped off without any issue. But looks like there is a screw comes from outside of the door holding the case and I am not sure how to unscrew this.
Please someone help me!
thanks
Old 08-10-06, 11:31 AM
P
I can open 2 push clips on the upper side of the interior panel and looked inside and but the lower part of the interior panel has a some kind of threaded screw. I don't know where the head of that screw is.
Old 08-10-06, 10:32 PM
davzack's Avatar
Usually it's near the handle. Sometimes they cover the head of the screw with a plastic plug. Do you see any circular seams in the plastic? If so, use a small pic and pop the plug out.
