Chrysler New Yorker 89 steering wheel
Old 08-01-06, 06:56 PM
Hello. The turn signal is loose and needs to be tightened as well as the ignition being locked. Do you know how I might remove the steering wheel to get to these problems? I removed the big bolt under the front of the steering wheel that seemed to be holding the wheel on, but it still would not slide off.
Old 08-04-06, 02:59 PM
steering wheel removal
You might be able to put nut on post, screw it level with post, then while someone pulls up on steering wheel, you tap on nut with hammer. Not too hard, as you can screw up threads on post. If this failes, you need a steering wheel puller, which can be rented at some parts stores. Hope this helps, Jerbear
Trackbacks are On
Pingbacks are On
Refbacks are On
