2000 Voyager Oil Light Indicator
Old 08-04-06, 06:08 PM
The oil light indicator along with a rather anoying alarm keeps going on while vehicle comes to idle. Removed valve cover and oil is pumping strong. Replaced oil sending unit and everything was back to normal for a couple of months. All of a sudden the problem started all over again. The engine isn't knocking at all which leads me to believe it's not a pressure problem. BTW, the van only has 60k miles.
Any advice would be much appreciated!
Old 08-04-06, 07:05 PM
Former Member's Avatar
Awh you have discovered why when you cruise thru your local auto scrap yard that there is a very long row of rather nice looking dodge/plymouth vans all parked very neatly ready to roll except for their crap engines.
Old 08-04-06, 07:49 PM
you need to check oil pressure with a mechanical guage and get the engine up to operating temperature and see what it reads at idle speed in gear, could have low oil pressure at idle and not make any engine noise even if you only had 5 psi of oil pressure at idle.
after checking it manually you will know whether you have a problem with the oil pump or engine, or an electrical problem with the sending unit or warning circuit.
