98 escort
Old 08-06-06, 06:36 AM
98 escort
how do i change a rear stut and coil spring on the escort?
Old 08-09-06, 11:20 PM
davzack's Avatar
That particular process is pretty involved and potentially dangerous if not done correctly. Failure to use the proper tools and safety equipment can cause you to end up with a coil spring imbeded in your forehead.
I would suggest that if you are really interested in DIY on this particular job, that you purchase a Chilton/Haynes manual at a local auto parts store for the exact description of the process along w/ helpful picutres. You will need to rent/purchase a strut spring compressor in order to perform the repair as well.
