Help! Car won't start!
Old 08-06-06, 05:01 PM
1998 Neon 2.0 I had a cracked exhaust manifold and replaced it, now it will not start! I think it isn't getting fuel because i can't hear the fuel pump run the few seconds when i turn on the key. I double checked all the things i undid for the exhaust job and found nothing related to this problem. The car simply will not start. It cranks over fine but doesn't seem to try and start. The fuel pump fuse is fine also. Help!
Old 08-07-06, 05:14 AM
the_tow_guy's Avatar
There will be a relay somewhere in the system as well that you will need to find and check.
You can find the schematics here:
http://www.autozone.com/servlet/UiBr...3d801e4241.jsp
Looks like there are two fuses involved, #'s 10 & 21 plus the relay.
