91 mitsu runability
Old 08-08-06, 06:35 PM
D
91 mitsu runability
I have a Mitsubishi mighty Max pick up that will start, but not continue to run on its own. It will continue to run, if after starting, pin 66 on the ECM is grounded externally. The ECM has been to the rebuild shop twice. Is there anything else I should check before rigging a switch and ground wire?
Old 08-09-06, 06:58 PM
davzack's Avatar
I think the pin you are talking about goes to the engine control relay. What color is the wire?
Old 08-10-06, 02:56 PM
D
White with a red stripe.
Any info you have is greatly appreciated.
Old 08-10-06, 10:29 PM
davzack's Avatar
That wire definitely goes to the Engine Control Relay...have you tried a new one? It's in the right kick panel.
Old 08-11-06, 07:30 PM
D
engine control relay is also new.
