Windshield wipers won't work
Old 08-11-06, 04:26 PM
I have a 1993 Mazda Protege. I noticed that the windshield wipers were going out. At first I thought it was the switch. The wipers would only work every once in a while or when they felt like it. Well, it was broken. So, I simply put in a toggle switch. This worked fine for a couple days. Then, it got to the point to where when you turn the switch on it would take 1-2 minutes for the wipers to come on. Finally they stopped coming on at all.
I figured maybe it was the toggle switch. So, I connected the wires directly to test that theory. I would hear a click in the steering column (I'm not talking about the click of two electrical wires together). It still didnt' work. So, I bought a new wiper motor. Put that in and still didn't work.
I noticed that the fuse was burnt. Reason being is that whomever owned the car before me had a 40A instead of a 30A fuse. Bought a new fuse and put that in.
I am still back and square one. Wipers still wont work.
Any suggestions?
Old 08-11-06, 06:42 PM
msargent's Avatar
You connected the wires directly to where? And from what source?
1 thing that does come to mind is a bad ground, rather than a bad power source...A bad ground can lead to higher resistance many electrical issues..
Old 08-11-06, 06:52 PM
There are three wires:
Black
Blue (with a yellow stripe)
Blue (with a red stripe)
I connect the black and one of the blue wires together. I hear a clicking in the steering column but nothing happens. If it's a bad ground, how do I fix that?
