Toyota Transponder key programing
Does anyone know if I can "on board program" my new aftermarket transponder key to my '03 Sienna XLE ? (I do have one master and I've found several step by step guides) There seems to be some confusion between the different sources online, and I havn't been sucessful following them yet. (as I did w/ the remote fobs!) Just want to make sure it can be done before spending anymore time on it
Thanks for taking the time.
Chuck Jacobi
Chuck Jacobi
REGISTRATION OF ADDITIONAL MASTER KEY
It is possible to register up to 7 master key codes including the already registered key code.
Make sure all doors are closed:
Insert already registered master key in the key
cylinder
Depress and release the acceleration pedal 5
times.
Depress and release the brake pedal 6 times,
and remove the master key.
Insert key to be registered in key cylinder.
Depress and release the acceleration pedal 1
time. (Security indicator blinks)
The registration mode completes After 60 sec. The
Security light will go out.
cylinder
times.
