2004 Malibu Classic
Old 08-12-06, 07:54 AM
2004 Malibu Classic
It seems lately when I'm travel on unlevel roadways I get a rattling noise from the passenager side front end. Can anyone offer and suggestion on what to look at? The chevy Malibu classic has 45,000 miles on it.
Old 08-12-06, 02:25 PM
an easy check
If you have hub caps remove them sometimes the tabs get weak.Just a thought pretty low miles still should be under warranty if it turns out to be more serious.
Old 08-12-06, 08:44 PM
davzack's Avatar
Lot's of stuff can cause the noise you describe...a bad strut mount, a bad strut, loose brake components, a loose heat shield on the exhaust, loose steering or suspension components, etc. You really should get up under there and have a look to see if everything it as it should be. Also pull the wheel off and inspect the wheel, brake system, etc.
Trackbacks are On
Pingbacks are On
Refbacks are On
