93 Labaron wont start
Old 08-13-06, 03:40 AM
Unhappy 93 Labaron wont start
1993 Chrysler Labaron wont start , drove to store ,came out and car will not turn over, battery is good . Hear clicking noise from relays under hood thats all.
Old 08-13-06, 11:45 AM
I would first check all battery terminals at battery for being CLEAN and tight (both positive and negative). You can clean them with an inexpensive battery brush avalible at parts stores. Clean the dried acid with baking soda/water mixture. Check the other ends of the cables also for cleanliness and tightness (negative will be grounded on frame or engine) and positive will probally be on the starter.
Make sure the battery has good CCA (Cold Cranking Amps). A Battery can check good with 12 volts but not have enough CCA.
If all that checks OK get an assistant to operate the key and find out exactly whats clicking.
