2001 Dodge Grand Caravan Air Controls
Old 08-18-06, 05:27 PM
B
I bought a 2001 grand caravan and the air worked but it's adjustment from low to high doesn't work. It only blows on full blast and then the controls for the rear of the van are now doing the same thing. The only problem seems to be the controls. Is it easy to fix and will it continue to happen?
Old 08-18-06, 06:14 PM
G
There is a resistor pack that controls the speeds. When it goes bad (which is not uncommon), the default is high speed only. Can't remember exactly where it is located, but it may be near the blower motor under the hood. Usually held in place by two small screws. Easy to replace and relatively inexpensive.
Old 08-18-06, 06:47 PM
B
Sweet! If someone could tell me a little more on where and how to fix this I would be most appreciative.
Old 08-18-06, 08:55 PM
G
It should cost between $20 and $ 30. I believe that it's under the dash, on the passenger side, on the heater ducting. How ever, someone should show up on the site who knows exactly.
