200 Explorer wiper fluid
Old 08-20-06, 02:31 PM
T
When i turn on my windshirld washer, it is very weak and now i noticed it leaks under the drivers dash and also outside by the door. Any ideas what it could be. thanks
Old 08-20-06, 03:59 PM
things to look at
Check to make sure the hoses are not broken also check the nozzle for dirt or wax build up.Have someone spray and see were the water goes it should only come out of the nozzles.
Old 08-20-06, 05:56 PM
T
help
a little bit of the fluid comes out on the windshield, but some drips on the floorboard and then it leaks to the outside somehow. Any ideas why it is leaking on floorboard and outside?
Old 08-21-06, 01:40 AM
were are the sprayers?
Are the sprayers on the hood or built into the wipers?
Old 08-24-06, 02:30 PM
T
wipers
The wipers are on the hood. the hose is hooked to the sprayer at the firewall.
Old 08-24-06, 03:04 PM
check it out
check all hoses for broken parts ,Lift hood and have someone spray and look for leaks pump either works or it does not work so motor is ok since you say it is weak.
Check the nozzles for junk like wax stick a small wire down them.
Old 08-24-06, 03:10 PM
T
From what i can see , it looks clear. I cant get to it to see it close up. Once I take off the wiper arms, there is a piece of plastic that covers the nozzle. What could cause it to leak into the floorboard?
