Bypass the A/C Compressor on a Camry?
Old 08-21-06, 06:12 AM
A
97 Toyota Camry LE 2.2 81,000
Was warned by mechanic that A/C compressor was on its last legs. This morning it locked up as predicted. I removed the belt to get the car running again, but, in doing so, left the alternator without a means of doing its job.
Even though I live in South Carolina where A/C is one of the basic necessities of life (along with food, water, clothing and shelter) I'm willing to forego it temporarily.
Any tips on running a new belt between the camshaft and the alternator directly? What size belt (brand/model number would be super)? Should I just go to my local mechanic and have him try on belts?
Is this a standard work-around? Are there any pratfalls I might encounter (other than being really sweaty)?
Thanks as always,
allenzachary
(Learning bit-by-bit)
Old 08-21-06, 08:08 AM
G
Received 3 Votes on 3 Posts
Seems to me you should be able to use the belt for a 97 Camray 2.2 without A/C. Have a nice day. Geo
Old 08-21-06, 07:27 PM
A
Sometimes it's the simplest solutions...
That are the hardest to see.
Works like a charm. Thanks for the input!
Old 08-22-06, 02:18 AM
N
Bad idea AIR.CON need to be run once in a while otherwise the seals get hard and start to leak. The besides the compressor you will have additional problem.
