1996 nissian maxima
Old 08-21-06, 01:56 PM
Smile 1996 nissian maxima
I parked my 1996 Nissian Maxima in the garage and now it won't start at all. The battery has a good charge but when I turn the switck nothing happens. All my lights on the dash work and the the alarm will set and disarm but nothing when I try to start the engine. I was thinking the ignition switch has gone bad but there was no warning and I tried to start the car five minutes after I parked it. Any Ideas.
Old 08-21-06, 04:03 PM
the_tow_guy's Avatar
Received 38 Votes on 30 Posts
A little more info, robo.
Do the lights dim when you turn the key and/or are there any sounds like clicks, clunks, etc? Possibility you have a bad park/neutral safety switch (auto trans) or clutch safety switch (manual trans). You might try shifting out of park and back and wiggle the shift lever around if it's automatic..
Old 08-22-06, 03:56 AM
you HAVE A BAD STARTER or solenoid either way change the whole thing not one but both items otherwise you may end up doing it twice.
