help needed (Engine Low Power)
Old 08-22-06, 07:20 AM
simpleguy1's Avatar
Hello,
well I have a 1991 mini van pontiac it has 240k miles, I know it s a lot anyway, the engine lost some of his power so iy doesn't exceed 60 mph and the rpm goes easily to the red zone about 7000 rpm, so I am wondering what s wrong and if there is a cheap way to repair it. there is another thing, sometimes when I accelerate the engine doesn't follow it seems like the gears didn't set, I guess it s from the transmission but I m not sure. if you can help or advice that would be great. thank you all.
Old 08-22-06, 07:32 AM
L
I assume this is an auto trans? If so have you checked the fluid? Has it been changed along with the filter? These are just thoughts to start with. Good luck!
Old 08-24-06, 08:04 AM
simpleguy1's Avatar
thks
thanks La859, I will check these things, the trans is auto.
