94 Buick Regal 3.8
Old 08-22-06, 03:18 PM
G
94 Buick Regal 3.8
i was driving to work and my car died.everything shut down.went back later and it started right back up.drove 1 mile and it shut down again.it will only run for a few minutes each time.someone told me it was my coil packs, so i changed them out but its doing the same thing.can somebody please help.its my only way to work.
Old 08-22-06, 04:05 PM
G
wanted to add that it does turnover but doesnt start
Old 08-22-06, 06:51 PM
Post no start
ok grtenn , heres what i need you to do , you need to pull of a spark plug wire , put a spark plug at the end of it , put the spark plug to ground , and crank the engine , do u have spark ??? i also need you to get a fuel pressure gauge , and test the fuel pressure while cranking , whats the pressure ??? this is the correct way to diagnose , then we can continue from here.
hey by the way if i told you it was the muffler bearings that need to be lubed would u do it ????
Old 08-23-06, 04:06 PM
G
ok ill try those things and get back to you.and yes i would lube it.thanks for the response.
