ading freon to a 92 ford escort
Old 08-26-06, 06:51 PM
B
if anyone could be so kind as to give me step by step directions to do so it would be much apreciated, im using freeze 12 and already have the recharge line
Old 08-27-06, 06:42 AM
the_tow_guy's Avatar
Received 145 Votes on 113 Posts
And a gauge set?
Most of the a/c pros here shy away from giving diy instructions on system charging due to the potential dangers involved.
Old 08-27-06, 12:51 PM
B
no gauge set but i know my system is completely empty i cant seem to find the low service port
Old 08-27-06, 01:05 PM
G
Received 23 Votes on 22 Posts
It would be a good time to convert it to 134a the whole conversion kit is about $30. Have a nice day. Geo
Edited transposed numbers only in reply.
Old 08-27-06, 01:37 PM
G
Received 2 Votes on 2 Posts
If you know it is completely empty, this would mean that you have opened the system at some point, or there is/was a leak which bled out all of the freon. First, you need to be sure that the system is now sealed against continuing leakage, and second, you will need to have a vacuum pump capable of drawing a vacuum to manufacturers specs before adding anything.
Old 08-27-06, 07:14 PM
B
the advice given by tow guy, and goldstar are right on the money.
any law abiding a/c tech won't give any info on how to charge a system on the diy forum, believing that most do not have the equiptment on hand to handle this type of job. remember, the freon in a system (any system, for that matter) does not wear out, get old, or loses it's ability to cool(or heat) over time.
and a true, workable conversion to another refridgerant, would cost way more than $30.00, seals, o-rings,fittings etc. and remember, you must make sure that there are no leaks in the system, no matter what refridgerant you are using. just some things to think about.
barry
Old 08-28-06, 06:35 PM
B
i bled it it but hey thanks for not helping me
Old 08-28-06, 07:01 PM
B
bluedragon,
define "i bled it" if you don't mind.
barry
Old 08-29-06, 04:05 AM
Sometimes "helping" consists of making sure you don't kill yourself.
