94 Camry Power Window Regulator Diagnosis
Old 09-01-06, 08:31 AM
Question 94 Camry Power Window Regulator Diagnosis
The driver side window goes down, then goes up progressively slower, making a rrrrrr noise from the motor. If I wait 30-60 seconds it goes up, sometimes all the way. I lubed the cables and pulleys. I assume the motor is damaged, but could it be the switch? Do I test at the motor for amps, volts, or both? Should I use a jumper to provide 12 volts from a fresh battery to test, or can I assume its the motor from the description of problem? An aftermarket regulator is 30+14shipping on Ebay. Am I taking big a chance with this cheap replacement?
Old 09-05-06, 11:18 PM
lube the window channel. where the glass slides up & down
