cherry red manifolds
Old 09-02-06, 07:23 PM
jim millett's Avatar
Angry cherry red manifolds
1988 chevy 350 when the motor get hot the manafolds glow has anyone seen a problem like this and what would be the cause
Old 09-02-06, 07:47 PM
nap's Avatar
nap
nap is offline
New Member
Received 2 Upvotes on 2 Posts
Way too much fuel. It continues to burn after entering the manifold and heats them up really well.
Either that or you are reving it at 10k+ rpm for exended periods of time.
Old 09-03-06, 12:37 AM
You might be running too lean, or your timing is too far advanced (or both). Headers will glow red, but cast iron manifolds should not. Do you have a temp gauge connected? If so, what kind of temps are you reading?
Old 09-03-06, 06:06 PM
C
Running too lean or timming is late! To much fuel actually is cooler than not enough fuel. Fuel enters and burns, if it all burns it will be very hot, more fuel will not all burn and will be cooler than if it burnt.
Old 09-03-06, 06:22 PM
ewizard's Avatar
Won't an air pump cause excess unburnt fuel to burn in the exhaust maninfold?
Isn't that what they were designed to do?
Too rich setting on an air pump model, eh?
Old 09-03-06, 06:41 PM
Timing is retarded- the mixture is still burning when the exhaust valve begins to open.
Old 09-04-06, 09:52 AM
K
Butterfly Valve
If it is old enough to have a temperature controlled butterfly valve on the exhaust manifold, they get rusty and do not open all the way. I have seen the exact same thing happen.
