'03 Toyota Camry cabin air filter
Old 09-11-06, 07:04 PM
Can anyone explain the procedure to replace the cabin air filter on a 2003 Toyota Camry LE? Thank you.
Old 09-11-06, 08:56 PM
Received 2 Votes on 2 Posts
Remove the screw on the right side of the glove box and disconnect the connecting rod. Squeeze the top sides of the box in towards each other and swing the box down. You will then see the carrier which holds the filter. Pull it out, remove the filter from the carrier and replace it. Shove the carrier back in and then swing the glove box back up, replacing the rod and screw.
If you haven't purchased a replacement, Purolator has them for about 1/2 the dealer price.
Old 09-15-06, 05:17 AM
that is correct
