84 celica lifter noise
Old 09-12-06, 08:43 AM
how is the best way to adjust lifters on a 22re motor?
Old 09-12-06, 02:05 PM
the_tow_guy's Avatar
Received 37 Votes on 29 Posts
Your terminology is a little off; the lifters are not adjusted, the valves are, or rather the rocker arms. Warm up engine. Remove valve cover. Rotate engine until the timing mark on the crank pulley is lined up at TDC (0 deg). Half of the rocker arms will be loose, half each of the intake and exhaust valves. Adjust the intakes to .008 and the exhausts to .012. Next rotate the engine 1 full turn and again align the timing mark to "0". Now the other half of the valves will be loose. Adjust as before. Reinstall valve cover.
Here's the full process. It's for trucks, but procedure is the same (the procedure for the Celica appears to be missing from its section).
http://www.autozone.com/servlet/UiBroker?ForwardPage=/az/cds/en_us/0900823d/80/18/82/a9/0900823d801882a9.jsp
Old 09-13-06, 12:00 AM
timing chain
I took off the valve cover ,found a guide broken on the right side ,in work now,,Thanks
Old 09-14-06, 09:04 AM
Received 4 Votes on 4 Posts
celica
Plasma:
I would replace both guides. Those actually serve as dampers for the lashing of the chain because of the length of it.
Hope this helps,
Bob
Old 09-14-06, 09:09 AM
When I think of the 22re, the first thing that comes to mind is "Timing chain Job from hell". lol..
