intermittent wipers
Old 09-15-06, 02:27 PM
charliet's Avatar
intermittent wipers
i have a 97 gmc suburban and when i try to use the intermittent cycle or the mist, i get anything but what i want. the mist might go a halve dozen times or 2 dozen times and usually ends up in the middle of the winshield. same with the intermitten, they will work fine for a bit, than go constantly and won't even turn off. i'm sure i'll probably have to take it to a garage, but would like to have an idea what i'm walking into. any input would be appreciated. thanks in advance
Old 09-15-06, 02:36 PM
Malfunctioning wipers on GM vehicles of that era are very common. So much so that you can buy a replacement pulse control module at AutoZone in the HELP! section. (The HELP! section is a display of commonly replaced items, and the brand name is HELP!) I just bought one there for my '93 Silverado and I believe it was around $30. It was a very simple fix that a do-it-yourselfer can do. I simply read the directions on the package, and it took about 5 minutes. Good luck.
Pecos
Old 09-15-06, 03:25 PM
Smile
If you know how to solder you can fix it for free.
