How do I get passenger door panel off 1993 Ford Explorer
I need to get door panel off to see about the window motor because the window will not come down.
Explorer door panel
Get all the screws out that you can find - may be some in the arm rest.
Then get an interior panel fork from an auto parts store. Get a cheapy unless you plan on doing this a lot.
Pry out the panel slightly to locate the panel retainers. They usually mount on the panel and press into a hole in the door.
Straddle each with your fork and pry out. They'll pop out for you. Don't try to just pull the panel off - you'll tear up the retainers and their mounts.
To reassemble line up the retainers with their respective holes and press them in.
Good luck,
Hope this helps, Bob
Good luck,
